iCloud Control Panel -- 1 vs 2
DigitalDawn
Outlook 2019 32-bit
I've read about all the things that the new iCloud (v2) control panel has added, but I'm curious, are there any things that version 1 could do that version 2 cannot?
Rich text appointments - v2 appointments don't support a rich text editor for notes. (I think it was removed as a bug fix for formatting issues. )
That is the only thing I can think of offhand.
V iCloud Control Panel v3.x Released Using Outlook 2
D iCLoud Control Panel 2.1 Using Outlook 3
G Forms error on iCloud calendar Using Outlook 18
V iCloud For Windows v15.x - Missing Email Features ? Using Outlook 4
B Outlook 2019 iCloud says “UN or PW is incorrect” but they are correct. Using Outlook 0
C reminders not synced by CodeTwo Sync for iCloud Using Outlook 2
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
KeithJB iCloud calendar sync only works one way! Using Outlook 3
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
B iCloud for Windows 11.2 disconnects by itself after 30-45 minutes Using Outlook 9
W Looks like the folder below has been deleted: "iCloud\Calendar" Using Outlook 1
Commodore iCloud mail with two-factor authentication Using Outlook 7
V iCloud Calendar invitations not sending Using Outlook 3
Horsepower Need iCloud mail only Using Outlook 1
Diane Poremsky iCloud, Outlook 2016, and Windows 10 Using Outlook 0
M icloud removed my contacts Using Outlook 7
