iCloud Control Panel v3.x Released
Vince
Outlook 2021 64 bit
On Windows7-64, the Apple Software Updater just notified me of iCloud Control Panel v3.0 being released. I said remind me later since I'm doing Outlook2007 iCloud Sync (until I backup my PST, etc.).
Anyone tried it yet?
I have it installed but i haven't really used it hard yet. I'm going to install it on a couple of test systems that only have one email account + iCloud so i can check it out better and see what it can do.
Anything of interest in Control Panel 3.0?
D iCLoud Control Panel 2.1 Using Outlook 3
D iCloud Control Panel -- 1 vs 2 Using Outlook 1
G Forms error on iCloud calendar Using Outlook 15
V iCloud For Windows v15.x - Missing Email Features ? Using Outlook 4
B Outlook 2019 iCloud says “UN or PW is incorrect” but they are correct. Using Outlook 0
C reminders not synced by CodeTwo Sync for iCloud Using Outlook 2
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
KeithJB iCloud calendar sync only works one way! Using Outlook 3
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
B iCloud for Windows 11.2 disconnects by itself after 30-45 minutes Using Outlook 9
W Looks like the folder below has been deleted: "iCloud\Calendar" Using Outlook 1
Commodore iCloud mail with two-factor authentication Using Outlook 7
V iCloud Calendar invitations not sending Using Outlook 3
Horsepower Need iCloud mail only Using Outlook 1
Diane Poremsky iCloud, Outlook 2016, and Windows 10 Using Outlook 0
M icloud removed my contacts Using Outlook 7
