Importer skips folders and messages
  • Thread starter Thread starter MA
MA
Dear,
We wrote a solution to import our user's non Outlook account using
Redemption. This solution has been working fine and now a user
reported that it skips folders for some account.
Solution import some folders then skips and import again. We could not
reproduce in-house with same data.
We are using Outlook 2003 (11.8313.8221). Is there any Outlook
settings which could interfare?
Sorry, I know its general question but we are confuse about what cause
this strange behaviour.
Thanks in advance.
Regards,
MA
Since no one here knows what settings you're talking about or exactly what
your code is doing or even what folders or type of folder you're talking
about I don't see how anyone could answer the question. You need to be more
specific and to possibly show some of the code you're using.
My guess is if you can't repro and only this user reports the problem that
the problem lies between his keyboard and chair (PEBKAC).
"MA" <malauddin@gmail.com> wrote in message
news:659fcaef-40ff-4bfe-a79a-96a1ef1e67e7@b7g2000pro.googlegroups.com...
> Dear,
> Thanks in advance.
> Regards,
> MA
Thanks Ken for your response.
Further debugging the code, we have found that GetFolderFromPath()
Redemption call causing an exception to access a specific folder thus
unable to process any messages.
We have a class library which return a MAPIFolder then we use
rdoSession.GetFolderFromPath(folder path) method to get an instance of
RDOFolder then create messages. Its been working great so far except
for one user where his folder name as: "90%Polyphe, 60%Cate".
- If we change the folder name to "90% Polyphe, 60% Cate" then it
works fine.
- If we use rdoSession.GetFolderFromID() method then we can access the
folder but unable to create any messages in that folder.
Its not machine/account specific, we can reproduce in different
account. Any thoughts?
Regards,
MA
That sounds like a bug in your version of Redemption's GetFolderFromPath()
method. If I were you I'd ping Dmitry and see if he knows of the bug and if
he has a fix in place.
news:eec092ee-8279-469e-8c32-54b77b18b722@x10g2000prk.googlegroups.com...
> works fine.
> Regards,
> MA
How exactly do you construct teh folder path? You yo uretrieve it from the
MAPIFolder.FodlerPath property? Or build it in your code?
Note tha tspecial charcaters (including "%") are encoded. E.g. in case of "%
something", the folder path will be "%% something".
GetFolderFromID is preferable. If you are unable to create in messages in
teh folder returned by GetFolderFromID, chances are you are passing 0 for
the last (Flags) parameter, which opens the folder in the read-only mode.
Pass MAPI_BEST_ACCESS (0x10) or Missing.Value (in case of .Net) - the
parameter is optional.
Dmitry Streblechenko (MVP)
> works fine.
> Regards,
> MA
Thanks Ken and Dmitry for your response.
I use MAPIFolder.FullFolderPath property:
rdoSession.GetFolderFromPath(olFolder.FullFolderPath)
You are spot on Dmitry about the flag in GetFolderFromID() method.
After using the Missing.Value flag, I can create messages in that
folder. I think Redemption docs need be bit clear about the flag.
RDOFolder rdofolder = rdoSession.GetFolderFromID(olFolder.EntryID,
olFolder.StoreID, System.Reflection.Missing.Value);
Thanks heaps guys for your valuable response.
Cheers,
MA
Cheers,
MA
For the other question, you could do something similar to what I do when I
play with text intended for XML or a file name, I run the code through a
sanity check procedure that makes sure any text is legal and formatted
correctly.
For example, replace all "&" characters with "&" for XML or replacing
all "/" characters with "-" for file names, etc.
news:9ceb6fe1-b6b5-4407-8a34-01c2ad180d75@k6g2000prg.googlegroups.com...
> Cheers,
> MA
J Move message skips messages when looping through mailbox Outlook VBA and Custom Forms 2
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 3
S How to get the actual Public Folder path from Favourites Folders Outlook VBA and Custom Forms 3
R Outlook with several IMAP accounts generating folders with 1111 suffix Using Outlook 0
icacream Outlook 2021 Win 10 - Nothing goes in my Drafts or Sent items folders ! Using Outlook 1
CWM330 Saving Data: Don't check certain folders Using Outlook 2
J Unable to delete folders in Outlook 2019 / Windows Using Outlook 0
D This folder up to date vs all folders up to date Using Outlook 1
e_a_g_l_e_p_i Adjusting font size in folders Using Outlook 1
Abraham Outlook 2013 Lost my folders when moving from PST to IMAP Using Outlook 11
J How to import many msg into different public folders in Outlook Outlook VBA and Custom Forms 7
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
A Moving Public Folders to New Database Exchange Server Administration 3
Paul Hobbs Automatically accept "Empty Folders" prompt Outlook VBA and Custom Forms 6
D How To Combine Share Task Folders in just one Folder Using Outlook 0
Witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
vodkasoda Hiding empty Folders Outlook VBA and Custom Forms 0
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
R The way expand/collapse folders is actually meant to work? Using Outlook 2
L Merge two contacts folders Using Outlook 1
