Tasks issue
Dan
Hi, I have a user that has shared tasks setup in Oulook 2003. There are 11 other users in his team, out of the 11, 10 are able to connect and work fine with the tasks except one. We have added the user in the permissions to get access and be able to see the tasks but as soon as you close the permissions and reopen them the user has gone. It only appears to be happening to this single user.
Any help welcome.
You should be able to put quite a few names in permissions, so it's not "full" (unless there are a lot more than these 11 people with permission to the folder) - but the recommended way to assign permissions is by creating a group in the AD, make the 11 members of the group then give the group permission to the folder.
Are there any error messages anywhere - start in the event log on the server.
Unfortunately I can't get access to the server logs. The issue lies with one specific user, the rest are fine. The users are added locally rather than through AD as there is a high turn over of staff and it is easier to manager if they are done locally. All the other users are ok, as soon as you add the troublesome user in the permissions check the relevant permissions, click ok they don't even show in the list of permissioned users. They just disappear as soon as you click ok. There are no error messages displaying, just the steps above and then back to nothing. I have tried the same with the calendar but they get the same. I tried with other users and they work fine, so I'm wondering if there is something account permissions based?
C multiple tasks issue Using Outlook 2
J Is the Windows Outlook Tasks module really going to be gone? Using Outlook 10
kburrows Online Archive - Do Not Archive Tasks Using Outlook 1
B Outlook tasks and PDF Using Outlook 4
petunia Outlook tasks module sunsetting? Exchange Server Administration 3
Fozzie Bear Shared Calendar For Scheduled Tasks Using Outlook.com accounts in Outlook 3
R unable to filter tasks when start date is on or before today Using Outlook 4
S Sync Outlook (2021) tasks with Microsoft To Do Using Outlook 1
L Format Lost between Tasks and To Do Using Outlook 0
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
O Tasks - how to display "snoozed" tasks and snooze-times? Using Outlook 7
T Outlook 2010 Tasks are not visible in To Do list Using Outlook 5
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
peterbata Shared Tasks Outlook for Mac Using Outlook 5
K Outlook tasks formatting Using Outlook 4
P Searching tasks that are archived Using Outlook 4
B All imported tasks appear in to-do list Using Outlook 3
T Extract Data From Outlook Tasks Using Outlook 0
I To-do bar (tasks) Using Outlook 1
O Tasks - Is there a postponed date column? Using Outlook 7
O Outlook 365 - Tasks are not synchronizing? Using Outlook 7
F some tasks are disappearing Using Outlook 4
F How to show assigned tasks under certain mailbox? Using Outlook 4
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
M tasks in todo list appearing twice Using Outlook 3
J what file contains contacts, tasks and appointments stored locally? Using Outlook 1
F Finding Meetings/Tasks in a date range Using Outlook 1
F Sharepoint tasks from multiple accounts in To-Do List Using Outlook 8
