Outlook and Icloud problems
I am hoping someone can help me. I am using Outlook with Icloud. I have multiple Icloud calenders in use and synced with Outlook.
Seems to work pretty good other then for what ever reason, Outlook will take a icloud calendar entries and move it to the "my calendars" outlook calendar. It still "shows" in the icloud-outlook calander. However, when I go to Icloud.com it is gone and missing. And when I go to edit the appointment in the icloud calendar, in outlook, it states "Your changes cannot be saved because you don't have permission to modify some or all of the items in this folder. Do you want to save a copy of this item in the default folder for the item?"
I am not sure why items are automatically being moved from the "Icloud calendar" to the outlook "my calenders" calendar. I share icloud calendars with others and don't want items unintentionally moved to outlook folders when I need them to remain in Icloud.
I am wondering if anyone else has experienced this?
All help is much appreciated!..
Daren
J Outlook 2010 and Icloud multiple calenders problems. Using Outlook 10
T Outlook 2007 - iTunes - iCloud Sync Problems Using Outlook 7
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
Diane Poremsky iCloud, Outlook 2016, and Windows 10 Using Outlook 0
Diane Poremsky Online Services in Outlook: Gmail, Yahoo, iCloud, AOL, GoDaddy Using Outlook 1
M Can't Delete iCloud Calendar Notifications From Outlook 2016 Using Outlook 0
Brendan Keeping Outlook contacts on PC after signing out of icloud Using Outlook 1
David Langer iCloud 5.0 for Windows and Outlook 2016 Using Outlook 5
S Using iCLoud Contacts for Outlook Email Using Outlook 1
230Grains iCloud COM Module Keeps de-selecting in Outlook 2013 Using Outlook 1
I iCloud Calendar and Contacts in Outlook 365 Using Outlook.com accounts in Outlook 2
K Outlook ICloud Data Folder Using Outlook 2
VCC Icloud/Outlook Syncing Issues Using Outlook 1
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
V Outlook not syncing with iCloud Using Outlook 5
M Outlook & Icloud Using Outlook.com accounts in Outlook 2
R Moving contacts from ICloud back to Outlook 2010 Using Outlook 4
R Disappearing data from outlook calendar after using icloud-ical Using Outlook 2
yooper46 Removal of iCloud contacts in Outlook contact list Using Outlook 8
