Tasks and To-Dos
abee
I have a lot of really old tasks and To-dos. I want to filter out on my screen my To-do flagged items in my mailbox from my Tasks - the end result is that on my Outlook Today screen I will see tasks and To-Do items separatly.
You can't create a separate todo list on the outlook today screen. You can create custom views to hide tasks or to-do's in the in the folders and in the task list on the to-do bar, but that won't work on the today screen.
J Is the Windows Outlook Tasks module really going to be gone? Using Outlook 10
kburrows Online Archive - Do Not Archive Tasks Using Outlook 1
B Outlook tasks and PDF Using Outlook 4
petunia Outlook tasks module sunsetting? Exchange Server Administration 3
Fozzie Bear Shared Calendar For Scheduled Tasks Using Outlook.com accounts in Outlook 3
R unable to filter tasks when start date is on or before today Using Outlook 4
S Sync Outlook (2021) tasks with Microsoft To Do Using Outlook 1
L Format Lost between Tasks and To Do Using Outlook 0
kburrows Reset Date to Keep Tasks from Archiving Using Outlook 9
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
O Tasks - how to display "snoozed" tasks and snooze-times? Using Outlook 7
T Outlook 2010 Tasks are not visible in To Do list Using Outlook 5
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
V Outlook 2016 Multiple recurring tasks getting created Using Outlook 0
peterbata Shared Tasks Outlook for Mac Using Outlook 5
K Outlook tasks formatting Using Outlook 4
P Searching tasks that are archived Using Outlook 4
B All imported tasks appear in to-do list Using Outlook 3
T Extract Data From Outlook Tasks Using Outlook 0
I To-do bar (tasks) Using Outlook 1
O Tasks - Is there a postponed date column? Using Outlook 7
O Outlook 365 - Tasks are not synchronizing? Using Outlook 7
F some tasks are disappearing Using Outlook 4
F How to show assigned tasks under certain mailbox? Using Outlook 4
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
M tasks in todo list appearing twice Using Outlook 3
J what file contains contacts, tasks and appointments stored locally? Using Outlook 1
F Finding Meetings/Tasks in a date range Using Outlook 1
F Sharepoint tasks from multiple accounts in To-Do List Using Outlook 8
F Search folder for tasks in all task folders Using Outlook 1
