Changed my "From" email address creates problem with previously saved contacts
JackPollack
I have changed my "from" email name in OL not to include my company name. As a result when I edit a previously created contact OL pops up a check name box and tells me it doesnt recognize contact (my old contact "from" name).
If I look at the contact "All mail fields" the "from" is MY old from address. This field is read only.
I was going to write a vb script to update this, but I cant even find an property to change.
I am able to get the contact item but contact.from, contact.sentonbehalfofname are not valid properties.
How can I change this via vb script or other way to update several hundred contacts
Re: Changed my "From" email address creates problem with previously saved cont
You get this dialog when you edit any contact? And its saying it doesn't recognize your own name? If shouldn't matter if the "owner" name is you old name - what matters is the current contact's name and address.
If I edit the email address filed of any old contacts created before I change my name the box pops up.
As I said I can see the old name in "All mail fields" - "from" on the contact record, but it is read only
The name on the all mail fields indicates who created the contact, it shouldn't affect the ability to edit the contact. The only way to change the From field is by exporting then importing, but it sounds more like the problem is with the addresses you are entering.
the addresses I am entering are ok, also if I created a new contact I dont have the problem.
If I export I guess i cant export to a pst. Which format should i use? will this reatin all of my data? do I need to map the fields, or just export and then import?
I don't think exporting to a pst will change your name, you need to export to excel or CSV. Can you post a screenshot of the dialog you get?
This is the dialog I get after changing an email address
That is the dialog i thought it was... but it's weird that its asking to check your name. Exporting to CSV or XLS then importing (and removing the old copies) should fix it.
just tried exporting to csv and also tried vcard. both fixed this problem but both lost custom picture. Many contacts have a custom picture that I need to keep. you can think of any way of copying or editing in place to change that field but retain pic
- - - Updated - - -
Update:
just copy & pasted the contact.The new duplicate contact from field says "unknown", but I still get the dialog. very strange
Yeah, images are not supported in exports. Copying the contacts using VBA should work. Are they the contact photos or business card images? Do you use more than the most common fields?
Three step process:
Save contact photos using VBA. Export (save) Outlook Contact photos - Slipstick Systems
Import the CSV.
Restore photos using VBA. Batch Import Photos into Outlook Contacts - Slipstick Systems
you could use my original plan and just use VBA to copy the contact, but you can't "just copy" the picture field, you need to save it to the hard drive then add it to the new contact. And you need to add every field to the code... the three steps should be a lot faster, especially because I have the code already. :)
I had to modify the pic export/import a bit because some of the pics only have company names (no first or last).
On a quick glance everything looks ok. Pics reimported and the number of contacts is ok. Need to spend some time looking at the data to make sure everything is ok. original problem with check names box is also fixed.
The only thing that concerns me is if I select all contacts and drag them to a folder on my desktop and look at the total file size of ll contacts the new total is a few MB smaller than the original total.
I dont think it is because I am missing any client pics. I tried it with a small subset that didint have anay pics and it looks like the export/import reduced the total size of that group aswell
In addition to removing the 'bad' From entry, you probably also removed / reset some other mapi properties. I wouldn't expect to lose more than a few KBs per contact though. Oh, if you have any attachments besides the image, you'll lose them as well.
So I started going through the new contacts and although all of the contact data appears to have imported correctly the new data set is quite different from the original in layout which is a big problem.
Most importantly the "file as" is missing, so all of the companies that I need to look for are now filed by contact name. In most cases the contact name for these companies is secondary.
Also I have noticed the the preferred phone numbers, order of numbers displayed, default address displayed, etc has defaulted back.
This extra meta data probably accounts for the smaller file size of this new set.
The new data is unusable in this format. Any other ideas on how to repair the original problem, or maybe a macro I can run on the new data that would extract the meta data from the original and apply it to the new set.
they are all different eg one may have business1, business2, another may be business1, assistant, mobile.
Also, what about the "display as" this is really important (also different for each contact)
That would be impossible to fix using code.
I have code that can fix the display as - but it would be one format for all. http://www.slipstick.com/outlook/contacts/bulk-change-outlook-contacts-email-display-name-format/
The other option is going back to my original plan of using a macro to copy all fields to a new contact. This won't help the phone # display (I don't think) but it will copy the display as field.
M Email Format getting changed to Plain Text Using Outlook 1
T I recently changed my pop3 email to an imap - question on folders Using Outlook 3
E "The operation cannot be performed because the message has been changed" Using Outlook 4
D Outlook 365 Outlook Message "Cannot be sent because the message has changed" Using Outlook 0
Cathy Rhone The properties of the message have been changed Using Outlook 1
V Contacts in O365 have changed?? Using Outlook 20
M Message list font changed after update Using Outlook 2
O How come default profile changed? Using Outlook 2
P Message List Font Changed Using Outlook 6
O Windows 1803 update : QAT and toolbar changed, language pack gone... Using Outlook 5
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
K Update Appointment category when changed in Excel Using Outlook 3
S Bullets Being Changed to Rectangles Using Outlook 15
E 365 Outlook changed from POP3 to IMAP,all contacts lost Using Outlook 3
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
J "This item has been changed still want to delete it" message Using Outlook 3
Horsepower Changed behavior in Outlook 365 Home and Gmail account Using Outlook 2
B "The properties of the message…have been changed" error Outlook VBA and Custom Forms 1
J Font size changed in new mail messages Using Outlook 5
B Address domain changed after pressing Ctrl+K Using Outlook 3
W Outlook 2007 changed from POP3 to IMAP Using Outlook 1
P Outlook 2007 Calendar Ribbon has changed and I can't fix it Using Outlook 10
T The Formatting Changes When A Recurring Appointment is Changed Using Outlook 1
J Outlook 2013 - changed an account from POP3 to IMAP, POP3 'Phantom' appears Using Outlook 15
E Inbox view changed can't get it right Using Outlook 0
B quick help with "changed by" field in a shared mailbox?? Using Outlook 3
S Meeting Time Changed to Central on calendar entries (not all) Using Outlook 2
G Outlook2013 - "From" name doesn't change even when changed in Account Setting Using Outlook 4
B Day count in rules gets changed in Office for Mac 2011 Using Outlook 1
B Appointment Tab has changed Using Outlook 2
S Outlook Contact Scroll bar direction - can it be changed? Using Outlook 3
J Changed Folder Structure; Outlook Doesn't Interact Properly Now Using Outlook 3
N Changed the "sender" account and lost all my text Using Outlook 2
J Calendar Appointments move when Computer Time Zone changed. Using Outlook 5
T Changed password now can't send/receive Using Outlook 1
B W7OL2010 Changed to imap, disabled old account, what to do about my calendar? Using Outlook 4
P How to restore my previous address book after an iPhone sync changed it Using Outlook 2
A Identifiying who changed or updated an appointment in Exchange 2007 Exchange Server Administration 7
P [SOLVED] Outlook-Hotmail Birthday Calendar changed by one day Using Outlook.com accounts in Outlook 8
R Outlook 2010 Changed "Recover Deleted Items" Behavior Using Outlook 11
P the outlook 2007 calendar cannot be saved because it was changed by another user or in another windo Using Outlook 4
W BCM in changed profile now unable to access BCM (Business Contact Manager) 1
S Changed Message class; forms with data resist. Outlook VBA and Custom Forms 5
A issue with the sender's name getting changed Outlook VBA and Custom Forms 1
