Outlook and icloud panel 3.0
KYMP0R
Recently upgraded to iCloud panel 3.0 for Windows using Outlook 2010 32 bit with Windows 7. I have been able to add, edit and sync my calendar events, reminders and tasks with the my iPhone and iPad until the upgrade. Now I get an error message "This event couldn't be created because of a server error". I have uninstalled and reinstalled iCloud panel 3.0 but get the same results. I have checked to make sure that the iCloud for Outlook add-on was enabled which it is. Been working on this for the last couple of days with no solutions or improvements. What can I do to rectify this situation?
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
Diane Poremsky iCloud, Outlook 2016, and Windows 10 Using Outlook 0
Diane Poremsky Online Services in Outlook: Gmail, Yahoo, iCloud, AOL, GoDaddy Using Outlook 1
M Can't Delete iCloud Calendar Notifications From Outlook 2016 Using Outlook 0
Brendan Keeping Outlook contacts on PC after signing out of icloud Using Outlook 1
David Langer iCloud 5.0 for Windows and Outlook 2016 Using Outlook 5
S Using iCLoud Contacts for Outlook Email Using Outlook 1
230Grains iCloud COM Module Keeps de-selecting in Outlook 2013 Using Outlook 1
I iCloud Calendar and Contacts in Outlook 365 Using Outlook.com accounts in Outlook 2
K Outlook ICloud Data Folder Using Outlook 2
VCC Icloud/Outlook Syncing Issues Using Outlook 1
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
V Outlook not syncing with iCloud Using Outlook 5
M Outlook & Icloud Using Outlook.com accounts in Outlook 2
R Moving contacts from ICloud back to Outlook 2010 Using Outlook 4
R Disappearing data from outlook calendar after using icloud-ical Using Outlook 2
yooper46 Removal of iCloud contacts in Outlook contact list Using Outlook 8
V Sync Outlook contacts/calendar on two computers using iCloud Using Outlook 2
Lucas attachments in outlook don't open, when Icloud is connected Using Outlook 0
