iCloud and Outlook help
rkdesto
I was using iCloud and Outlook seamlessly until a month ago when it just stopped syncing from my PC (devices sync fine to icloud). I have uninstalled, re=installed, set up my icloud email account in Outlook (which works fine), but nothing works. Everytime I go into the iCloud control panel, there is no box next to calendar, contacts, or notes.
Can anyone out there help me? Now that I've uninstalled and reinstalled, my Outlook icloud calendar and contacts are frozen! I will gladly pay tech support to just do it for me because I am so tired of wasting my time with this.
Randi
Are you using iCloud 1 or iCloud 2? (ICloud 2 has one box to select Mail, Calendar, contacts, tasks - iCloud 1 has separate selections for mail, calendar and contacts)
did you sign out of iCloud and then sign back in?
what do you mean by 'frozen'?
I'm using iCloud 2. I have uninstalled, reinstalled, rebooted and nothing is working. Downloaded it into my laptop to see if it would work there, and it installed perfectly and works perfectly.
On my PC I continually get a box telling me to go to my control panel to repair iCloud. I do that and get the box again. It's almost like something in my computer is stopping iCloud from installing correctly. On the iCloud forum someone said that they had to delete a mail.pst file. But I can't find that on my PC. I'm stumped...and anxious to have my contacts and calendar working again.
Can you help?
Randi
Exit the iCloud applet and go to C:\Users\username\AppData\Local\EA5A7B1F-55B8-45AC-9BD7-DEF590241414.aplzod and delete the contents. (the GUID # might be different) iCloud will rebuild it when you restart it.
A little more investigation...
Tried to follow this path from Outlook accounts, but you can see it's nowhere to be found.
Randi
In looking at your folder screenshot, did you move the user folders?
The folders in the user path are normally hidden and you can either copy the path from the dialog or type %localappdata%\Microsoft\Outlook into windows explorer to find them.
Marty,
I tried that search and it came up empty. Also, I didn't move any of the folders. The Office 2010 program was added by a computer tech person who is not responding to my emails for help, other than sending me an iCloud forum screen that talks about how you should get rid of iCloud with Outlook.
Any other suggestions?
Randi
iCloud is not THAT bad - it's not perfect by any means, but once you understand the idiosyncrasies it works pretty good. iCloud and Outlook Sync Problems and Solutions
Your second screenshot with the folder tree is not right - You should have a randi's pc folder in the user path - that is where outlook says the pst is, but its not there. Are you using junction points or something to repoint the folders?
I did find a Randi's PC folder in the user path. Here's a screen capture. Not sure what a junction point is. You can see that I also have Randi's PC on it's own, about the C folder. I'm assuming they are the same?
In Outlook 2007 I could try to export a file and then see where the pst is. But in 2010 version, I can't even see how to export a file. My former computer guy installed Office 2010 from his own copy. I don't even have one to uninstall and reinstall.Outlook help 3.JPG
I also just reinstalled iCloud for the 4th time. On the previous attempts, all of my icloud folders remained in Outlook, but just weren't accessible. Now the folders are GONE!...all of my calendar and all of my contacts!!! Since I had been using this exclusively before I realized it wasn't syncing, that was my most current calendar and contact list.
The one under Desktop is a user-friendly version of the one under C:\users\. If you don't know what junction points, you aren't using it.
I'm glad you called him a former computer guy - it sounds like he installed an illegal copy. To export a pst go to File, Open, Import - export.
They're on the iPhone and iPad, but for a month I was only inputing on my PC and didn't realize they weren't syncing with iphone and ipad. so those will be lost now.
Yes, I have signed in and out of iCloud many times...still nothing.
don't know what to do next. Nothing in Randi's PC folder looks like it is linked to outlook. It's like something is running that is stopping iCloud from repairing or installing correctly. Every single time I get a box that keeps telling me to repair it. Now it is not even showing an iCloud folder in Outlook.
I also can't seem to find outlook in the C: tree. any suggestions?
I just did a plain old Outlook search and may have found something! I see aplzod...here's the saved screen. should I delete them?
No, don't delete those. They are installation files.
Open windows explorer. Type %localappdata% in the address bar and press enter. Do you see a folder with a long name ending in .aplzod?
Quickie video showing what you should see - icloud-folder - dicot's library
If you don't see the aplzod folder and contents, close Outlook, sign out of iCloud then sign back in.
Did that, and at least it took me to the right place. But...no folder with apzod. Actually, no folders with numbers at all. In the temp file there are lots of folders with numbers all in parentheses. Here is the saved screen.
Thanks! I really appreciate your help :rolleyes:
Diane, you are the best! I am back in business with Outlook in the iCloud. Thank you so much for sticking with me until it worked.
Randi
V Outlook 2021 Outlook-2021 (64-bit) and iCloud-for-Windows v13.0 - It Works Good. Using Outlook 12
Diane Poremsky iCloud, Outlook 2016, and Windows 10 Using Outlook 0
Diane Poremsky Online Services in Outlook: Gmail, Yahoo, iCloud, AOL, GoDaddy Using Outlook 1
M Can't Delete iCloud Calendar Notifications From Outlook 2016 Using Outlook 0
Brendan Keeping Outlook contacts on PC after signing out of icloud Using Outlook 1
David Langer iCloud 5.0 for Windows and Outlook 2016 Using Outlook 5
S Using iCLoud Contacts for Outlook Email Using Outlook 1
230Grains iCloud COM Module Keeps de-selecting in Outlook 2013 Using Outlook 1
I iCloud Calendar and Contacts in Outlook 365 Using Outlook.com accounts in Outlook 2
K Outlook ICloud Data Folder Using Outlook 2
VCC Icloud/Outlook Syncing Issues Using Outlook 1
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
V Outlook not syncing with iCloud Using Outlook 5
M Outlook & Icloud Using Outlook.com accounts in Outlook 2
R Moving contacts from ICloud back to Outlook 2010 Using Outlook 4
R Disappearing data from outlook calendar after using icloud-ical Using Outlook 2
yooper46 Removal of iCloud contacts in Outlook contact list Using Outlook 8
V Sync Outlook contacts/calendar on two computers using iCloud Using Outlook 2
Lucas attachments in outlook don't open, when Icloud is connected Using Outlook 0
