Sync laptop without using VPN
dkfif
Older version
I have a laptop that is running outlook 2000. My server is running Server 2003 with exchange. When in the office, I can connect to my server via cable and sync all my outlook folders to my laptop. All works well. I am running outlook in corporate/workgroup mode. I recently changed my cable provider to Verizon who makes creating a VPN connection just short of impossible. So..when I'm at home, I cannot sync and that is a problem for me since my office is a long way away. My question is: Can I somehow sync with Outlook 2000 and a 2003 server without using VPN? For what its worth, I have an ipad and I just put in the IP addresses of my server and it sync's everything great. I doesn't work when I try that with Outlook on my laptop. Any ideas how to do this (or a definitive answer it won't work) would be most appreciated. Thanks.
Thanks for the reply. My laptop is running XP. I think I can find an old version of ActiveSync (4.5 maybe). Could I get it to work if I put on ActiveSync??
T IMAP mail sync is extremely slow Using Outlook 7
S Import pst file into 365 desktop and have it sync one Using Outlook.com accounts in Outlook 2
C reminders not synced by CodeTwo Sync for iCloud Using Outlook 2
P How to clear out all contacts in iCloud, so I can use iCloud-based sync program Using Outlook 1
S Sync Outlook (2021) tasks with Microsoft To Do Using Outlook 1
KeithJB iCloud calendar sync only works one way! Using Outlook 3
Commodore iTunes sync on a new computer - any issues to be expected? Using Outlook 9
